Transaction not applied
Post by andrew » Mon Mar 07, 2016 9:56 am
From a QCAD user:
I'm trying to run a transaction but it has no effect:
RTransaction t(document.getStorage(), QObject::tr("Set Layer Properties"));
layer->setFrozen(false);
layer->setLocked(false);
t.addObject(layer, false);
t.end();
Re: Transaction not applied
Post by andrew » Mon Mar 07, 2016 10:03 am
Transactions are usually only used on a lower level in QCAD (a transaction records all changes on a set of objects caused by an operation, i.e. when adding, deleting or modifying objects).
Operations are the concept used for more comfortable, higher level modifications:
RModifyObjectsOperation op;
op.addObject(layer);
di->applyOperation(&op);
This will update the document and also the views, layer lists, etc. accordingly. A transaction object is returned by applyOperation which contains information about objects that were changed.
