Qt Build with VS2013
slymn++
Post by slymn++ » Wed Feb 17, 2016 3:35 pm
Hi
I download qt4.7.4 source file.
I installed vs 2013.
How can I build qt?
Re: Qt Build with VS2013
Post by andrew » Wed Feb 17, 2016 3:55 pm
We have detailed instructions for compiling QCAD / Qt from sources at:
http://www.qcad.org/en/component/conten ... om-sources
If you experience any problems, there are also more detailed howtos.
slymn++
Post by slymn++ » Wed Feb 17, 2016 4:51 pm
Thanks Andrew
Can I compile QCAD in QT5.5?
Post by andrew » Wed Feb 17, 2016 4:56 pm
slymn++ wrote:Can I compile QCAD in QT5.5?
Yes:
http://www.qcad.org/en/qcad-documentati ... -platforms
slymn++
Post by slymn++ » Thu Feb 18, 2016 8:23 am
Thanks Artem
I installed qt5.5.1
I get error.
:-1: error: dependent '..\..\..\..\..\..\qcad-3.12.7.0\src\3rdparty\qt-labs-qtscriptgenerator-5.5.0\generated_cpp\com_trolltech_qt_core\qtscript_QAbstractAnimation.cpp' does not exist.
Post by andrew » Thu Feb 18, 2016 9:17 am
Did you follow our instructions at http://www.qcad.org/en/component/conten ... om-sources or try a different way?
slymn++
Post by slymn++ » Thu Feb 18, 2016 10:49 am
I installed qt5.5.1 by online installer
I set QMAKESPEC -> win64-msvc2013
in cygwin
KULLANICI@M4500 /cygdrive/c/QCAD/qcad-3.12.7.0
$ qmake -r
Could not find qmake configuration file win64-msvc2013.
Error processing project file: C:\QCAD\qcad-3.12.7.0\qcad.pro
Can I compile from qt5.5 interface?
Post by andrew » Thu Feb 18, 2016 10:57 am
A list of available QMAKESPEC values is available in qt-everywhere-opensource-src-5.5.1/qtbase/mkspecs (each directory name represents a possible value for QMAKESPEC). You probably want to use win32-msvc2013 even if you plan to compile 64bit binaries.
Building 64bit binaries under Windows requires some additional steps:
http://www.holoborodko.com/pavel/2011/0 ... mment-7546
Once everything is set up, yes. I've never done that under Windows, since I'm only porting to that platform, not doing any development on it.
slymn++
Post by slymn++ » Thu Feb 18, 2016 4:31 pm
Hi Andrew
I downloaded Qt5.5.0 then compiled.
I get "depended" error, then I removed POST_TARGETDEPS in dxf.pro, and stemmer.pro
then succesfully compiled, created qcad.exe in debug file. But qcad crashed in splash screen(%70)
slymn++
Post by slymn++ » Thu Feb 18, 2016 4:49 pm
Compiled release mode. it works :)
