Export PDF MultiPageSettings not work
duccoder
Post by duccoder » Fri Jan 29, 2016 11:01 am
Hi, I follow code from here http://qcad.org/doc/qcad/latest/develop ... xport.html
And I modify section number of pages:
// number of pages (rows / columns):
  document.setVariable("MultiPageSettings/Rows", 2);
  document.setVariable("MultiPageSettings/Columns", 2);
But it not work, PDF file output only 1 page. I try draw more Line has coordinate over page but not show
I work with Qcad 3.12.5 Pro
example.pdf
(1.32 KiB) Downloaded 461 times
ExPdfExport.js
(3.42 KiB) Downloaded 464 times
duccoder
Re: Export PDF MultiPageSettings not work
Post by duccoder » Mon Feb 15, 2016 9:58 am
Hi Andrew, can you help me check this issuse
Post by andrew » Mon Feb 15, 2016 10:22 am
I haven't had time yet to look into this.
duccoder
Post by duccoder » Fri Mar 04, 2016 5:24 am
Hi Andrew, I think problem from here
https://github.com/qcad/qcad/blob/95aea ... t.js#L1210
Print.getColumns = function(document) {
    var appWin = RMainWindowQt.getMainWindow();
    if (isNull(appWin) || appWin.property("PrintPreview/InitialZoom")==="View") {
        return 1;
    return EAction.getIntValue("MultiPageSettings/Columns", 1, document);
So when run autostart from commandline, appWin always null => pagers always = 1
Post by andrew » Mon Mar 07, 2016 10:24 am
Thanks for looking into this. You can update Print.js accordingly:
https://github.com/qcad/qcad/commit/e6f ... e1177135d7
