ECMA exportFile fileVersion
duccoder
Post by duccoder » Fri Dec 18, 2015 2:43 am
Hi, I found format exportFile:
bool RDocumentInterface::exportFile	(	const QString & 	fileName,
const QString & 	fileVersion = "",
bool 	resetModified = true
Then I apply:
documentInterface.exportFile(output, 'DXF 2007');
It's work well.
But now, I need export DXF R13 or DWG R13 or another versions, but I can't found define fileVersion on doc.
Any one can help me
Re: ECMA exportFile fileVersion
Post by andrew » Fri Dec 18, 2015 9:16 am
Any string for 'fileVersion' containing "R27" or "2013" will produce DXF R27 if available. Pass a string containing "R13" to get DXF or DWG R13, etc.
The format string typically comes from the format selected in a file dialog, e.g. "DXF R13 Drawing File".
