Ecma getIntersectionPoints argument limited
duccoder
Post by duccoder » Thu Aug 27, 2015 3:40 am
Hi Andrew, I use ECMAScript to get intersection points between 2 entities with Qcad Pro.
getIntersectionPoints (const RShape &other, bool limited=true, bool same=false, bool force=false) const
And my sample code:
var rs1 = new RSpline();
  rs1.appendFitPoint(new RVector(1, 2));
  rs1.appendFitPoint(new RVector(3, 3));
  rs1.appendFitPoint(new RVector(6, 10));
  rs1.appendFitPoint(new RVector(21, 25));
  var sp1 = drawSpline('sp1',rs1);
  var rs2 = new RSpline();
  rs2.appendFitPoint(new RVector(-1, -1));
  rs2.appendFitPoint(new RVector(3, 2));
  rs2.appendFitPoint(new RVector(6, 3));
  rs2.appendFitPoint(new RVector(9, 10));
  rs2.appendFitPoint(new RVector(24, 25));
  var sp2 = drawSpline('sp2',rs2);
  var rl1 = new RLine(new RVector(5, 0), new RVector(25, 0));
  var l1 = drawLine('l1',rl1);
  print('l1 vs s1: ' + rl1.getIntersectionPoints(rs1, false));
  print('l1 vs s2:' + rl1.getIntersectionPoints(rs2, false));
And dxf file:
Then I run my code with:
- QCAD 3.9.4:
l1 vs s1:
l1 vs s2:RVector(0.0292292, 0, 0, true)
Execution time: 33 milliseconds
but when 3.10.10
l1 vs s1:
l1 vs s1:
Execution time: 31 milliseconds
So, I can't get intersection of l1 and s1 with Qcad 3.10.10
Help me solve this, please
Re: Ecma getIntersectionPoints argument limited
Post by andrew » Thu Aug 27, 2015 7:44 am
Thanks for your report.
Moved issue to bug tracker at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1253
Moved topic to appropriate forum (Developers).
