Linetype name inconsistency
mink
Post by mink » Thu Jul 09, 2015 1:18 pm
Hy Andrew,
I have been silent for quite some time programming a lot of qcad plugin functionality without serious problems. This leads to a simple : Thanks a lot for your good work!
However, I found a little inconsistency on linetype names: wenn I use a new drawing, add a layer with lintype by layer, and draw a line on this layer, the graphics are ok. Getting the CPP-Entiypointer to the line as pEntity, and use
			RLinetypePattern ltpat = pEntity->getLinetypePattern();
			QString ltName = ltpat.getName();
ltName contains the String "BYLAYER" (all uppercase).
Saving the drawing (as dxf), close it and load again.
Applying the same code segment leeds to ltNmae containing "ByLayer" (Camel case ...).
No big thing, but a little inconsistent ....
Ulrich
Re: Linetype name inconsistency
Post by andrew » Mon Jul 13, 2015 8:23 am
Layer names, block names and linetype names are case insensitive by definition. Some (older) DXF versions always store BYLAYER (upper case), some seem to prefer ByLayer. This should happen behind the scene though.
mink
Post by mink » Tue Jul 14, 2015 10:19 am
Thanks for the info!
Ulrich
