My first extension for QCAD that creates parallel lines
pietro_72_
Location: http://creativitainformaticart.altervista.org
Post by pietro_72_ » Sat Jun 06, 2015 5:18 pm
La mia prima estensione per QCAD che crea linee parallele :D
Se interessa può essere scaricata a questo indirizzo:
http://pietro72li.altervista.org/file_s ... r_QCAD.zip
Translation by Google
My first extension for QCAD that creates parallel lines :D
If you are interested in you can be downloaded at this address:
Re: My first extension for QCAD that creates parallel lines
Post by andrew » Mon Jun 08, 2015 4:03 pm
Thanks for your valuable contribution!
Just some quick and friendly feedback :)
- I understand that not everyone is comfortable programming in English, I'm not a native english speaker either ;) However, class names should be kept in English always, e.g. 'LineParallelPP' instead of Linee_parallele. This is to make sure that everyone understands at least what a class is about.
- CamelCase should be preferred over underscores (at least for class names).
- Supporting libraries (such as Equazioni_di_Cona_Pietro.js) might of course use their own conventions...
- All text strings in code such as qsTr("Primo punto") should be in English. Translations into other languages can then be added using the Qt translation tools (lupdate, lrelease, Qt Linguist).
Let me know if you need any help to update the strings.
pietro_72_
Post by pietro_72_ » Tue Jun 09, 2015 11:22 am
Grazie per i tuoi consigli, per la tua disponibilità e per il vostro lavoro.
Thanks for your advice, for your time and for your work.
