Repopulate QT Widget based on XML File
wildspidee
Post by wildspidee » Mon Apr 13, 2015 3:21 pm
Andrew,
The add-on that I created is working well. There is one thing I was not able to accomplish that needs to be done. Right now, the only data that is opened in the QT widget dialog is the last data set entered. I would like the ability to select any prior XML file to populate the widget for changes and a subsequent save.
Are there any examples within the program that do this? The code is currently using the combination createWidget() / restoreState(). I would need code after the creation to open the selected XML and populate the UI dialog with it.
Any help would be appreciated. Thank you,
Lori
Re: Repopulate QT Widget based on XML File
Post by andrew » Mon Apr 13, 2015 3:30 pm
saveState / restoreState uses the configuration file to save the contents of a widget.
To read the data from an XML file (e.g. to fill in the GUI components accordingly), you'd have to use QXmlSimpleReader.
wildspidee
Post by wildspidee » Mon Apr 13, 2015 3:37 pm
Thank you.
