Custom Properties with title != "QCAD" disapear
mink
Post by mink » Mon Mar 09, 2015 2:03 pm
Hi all.
custom properties wear a title, a key and a value. As long as i choose "QCAD" as title, everything works as expected.
However, when I set another title programatically, again everything is ok as long as the drawing is active (the property editor shows title as well as key / value). When I save (as dxf, any revision (to R27)) the drawing and activate it again, theese custom properties disapeared.
Bug or feature? :wink:
Ulrich
Re: Custom Properties with title != "QCAD" disapear
Post by andrew » Mon Mar 09, 2015 2:45 pm
QCAD stores custom properties in the format key:value (as string). Other applications store custom properties differently.
For this reason, the DXF exporter must know if a custom property is a QCAD supported property or a custom property from another application in an unknown / unsupported format.
This check is performed by comparing the property title with qApp.applicationName, so you might just want to set qApp.applicationName to your desired title.
mink
Post by mink » Mon Mar 09, 2015 3:10 pm
Hello Andrew,
thanks for the info!
Ulrich
