Flow:
- Click shapes
- Click rectangle from points
- Draw rectangle on canvas
- Enter or Right click
- Escape to exit command back to selection tool Segfault
void RDocumentInterface::deleteTerminatedActions() { bool removed = false; while (currentActions.size()>0 && currentActions.top()->isTerminated()) { cursorPosition = RVector::invalid; RAction* currentAction = currentActions.top(); currentAction->finishEvent(); setClickMode(RAction::PickingDisabled); // remember GUI action group: QString group; if (currentAction->getGuiAction()!=NULL && // currentAction is null !currentAction->getGuiAction()->getGroup().isEmpty() && currentAction->isOverride()) { group = currentAction->getGuiAction()->getGroup(); } currentActions.pop(); delete currentAction; if (!group.isEmpty()) { RGuiAction::triggerGroupDefault(group); } removed = true; } // if one or more actions have been terminated, resume previous action // or default action: if (removed) { if (currentActions.size()>0) { currentActions.top()->resumeEvent(); } else if (defaultAction!=NULL) { defaultAction->resumeEvent(); } } // run next queued action: if (queuedActions.size()>0) { setCurrentAction(queuedActions.dequeue()); } }Or, I get an error around this function:
/** * Repaints all views. */ void RDocumentInterface::repaintViews() { if (deleting) { return; } QList<RGraphicsScene*>::iterator it; for (it=scenes.begin(); it!=scenes.end(); it++) { (*it)->repaintViews(); } }This has issues because there is a NULL RGraphicsScene pointer or just an invalid pointer (i.e. it's already been freed). I do not call repaintViews() explicitly anywhere, so this is coming from somewhere else (the debug trace is useless since its via EMCAScript).
The log file from a debug build is here:
Debugging starts
&"warning: GDB: Failed to set controlling terminal: Inappropriate ioctl for device\n"
Debug: RDxfPlugin::init
Debug: RExamplePlugin::init
Debug: TransactionListenerPlugin::init
Debug: loading patterns from file: "/home/kevin/workspace/qcad/linetypes/metric/qcadiso.lin"
Debug: loading patterns from file: "/home/kevin/workspace/qcad/linetypes/imperial/qcad.lin"
Warning: RScriptHandlerEcma::RScriptHandlerEcma: script debugger enabled! Not recommended.
Debug: TIMER: 86 ms - "loading add-ons"
Warning: "QFormBuilder was unable to create a custom widget of the class 'QWebView'; defaulting to base class 'QWidget'."
Debug: TIMER: 377 ms - "initializing add-ons"
Debug: TransactionListenerPlugin::postInit
Debug: got transaction
Debug: IDs of objects that were changed: ()
Debug: List of changed objects:
Debug: End of list
Debug: IDs of objects that were changed: (4, 44, 45, 46, 47)
Debug: Changed object: RBlock(RObject(id: 4, handle: "0x4", document: "0x5849eb0", address: "0x5e02440", undone: 0, protected: 0), name: "*Model_Space", origin: RVector(0, 0, 0, true), frozen: false, anonymous: false)
Debug: Changed object: RLineEntity(REntity(RObject(id: 44, handle: "0x2c", document: "0x5849eb0", address: "0x8ea5df0", undone: 0, protected: 0), type: 7, layerId: 3, blockId: 4, parentId: -1, childIds: QSet() , lineweight: -1 , linetypeId: 0 , linetypeScale: 1 , color: RColor(ByLayer) , drawOrder: 0 , selectionStatus: false , boundingBoxes: (RBox(RVector(0, 0, 0, true) - RVector(90, 0, 0, true)) ) ) , startPoint: RVector(0, 0, 0, true), endPoint: RVector(90, 0, 0, true))
Debug: Changed object: RLineEntity(REntity(RObject(id: 45, handle: "0x2d", document: "0x5849eb0", address: "0x8ea5df0", undone: 0, protected: 0), type: 7, layerId: 3, blockId: 4, parentId: -1, childIds: QSet() , lineweight: -1 , linetypeId: 0 , linetypeScale: 1 , color: RColor(ByLayer) , drawOrder: 1 , selectionStatus: false , boundingBoxes: (RBox(RVector(90, 0, 0, true) - RVector(90, 30, 0, true)) ) ) , startPoint: RVector(90, 0, 0, true), endPoint: RVector(90, 30, 0, true))
Debug: Changed object: RLineEntity(REntity(RObject(id: 46, handle: "0x2e", document: "0x5849eb0", address: "0x8ea5df0", undone: 0, protected: 0), type: 7, layerId: 3, blockId: 4, parentId: -1, childIds: QSet() , lineweight: -1 , linetypeId: 0 , linetypeScale: 1 , color: RColor(ByLayer) , drawOrder: 2 , selectionStatus: false , boundingBoxes: (RBox(RVector(0, 30, 0, true) - RVector(90, 30, 0, true)) ) ) , startPoint: RVector(90, 30, 0, true), endPoint: RVector(0, 30, 0, true))
Debug: Changed object: RLineEntity(REntity(RObject(id: 47, handle: "0x2f", document: "0x5849eb0", address: "0x8ea5df0", undone: 0, protected: 0), type: 7, layerId: 3, blockId: 4, parentId: -1, childIds: QSet() , lineweight: -1 , linetypeId: 0 , linetypeScale: 1 , color: RColor(ByLayer) , drawOrder: 3 , selectionStatus: false , boundingBoxes: (RBox(RVector(0, 0, 0, true) - RVector(0, 30, 0, true)) ) ) , startPoint: RVector(0, 30, 0, true), endPoint: RVector(0, 0, 0, true))
Debug: End of list
I'm looking for any insight in to what might be causing a null action to be put onto the stack.
Edit:
I've been digging around, and I've am fairly confident that the issue is that something is being deleted by the EMCA script interpretter within the action stack that is not cleaning itself up within the C++ side. Some action is trying to get it's own GUI action, but the action was already deleted by the script engine.
I have no idea what would cause this.
Side note, I'm unsure if this was intentional, but I did find this:
RGraphicsScene::~RGraphicsScene() { deleting = true; while (!views.isEmpty()) { delete views.takeFirst(); } documentInterface.unregisterScene(*this); // this was missing, I added it because the ctor registers }Edit2: I think it might be a race condition, it only seems to be consistent with pressing "Esc" multiple times quickly.
