I'm stuck on a problem where I am obviously missing a point ....
What I want to achieve: Create Objects by C++ as background-Data. Then I want to access data of theese objects with a script to be able to visualize it (by creating drawing objects).
The error message from the script is:
Uncaught exception at scripts/DACad/DAassignMachineModel/DAassignMachineModel.js:76: TypeError: Result of expression 'this.damachines.getNumberOfMachines' [undefined] is not a function.
// set values to Modellist widgets, and prepare sewfield values
this.globalDACADGlobals = new DACADGlobals();
this.damachines = this.globalDACADGlobals.getTheMachineModelList();
qDebug("damachines = ", this.damachines);
var nMachines = this.damachines.getNumberOfMachines();
for (var i = 0; i < nMachines; i++)
var machName = this.daMachines.getMachineName(i);
this.modelList.addItem(machName);
The class DACADGlobals iterface is as follows:
#ifndef DACADGLOBALS_H_
#define DACADGLOBALS_H_
#include <QtCore/qobject.h>
#include <QString>
#include <QSharedPointer>
#include <QDebug>
#include "DAMachineModelVector.h"
// .... some enums without importance
class DACADGlobals : public QObject
Q_OBJECT
public:
DACADGlobals();
virtual ~DACADGlobals();
public slots:
DAMachineModelVector * getTheMachineModelList();
private:
Q_DECLARE_METATYPE( DACADGlobals* )
#endif /* DACADGLOBALS_H_ */
#include "DACADGlobals.h"
static DAMachineModelVector *s_pMachineModelList(NULL);
DACADGlobals::DACADGlobals()
: QObject()
DACADGlobals::~DACADGlobals()
DAMachineModelVector * DACADGlobals::getTheMachineModelList()
if (s_pMachineModelList == NULL )
s_pMachineModelList = new DAMachineModelVector();
s_pMachineModelList->init();
qDebug("s_pMachineModelList = %08x", s_pMachineModelList);
return s_pMachineModelList;
void DACADPlugin::initScriptExtensions(QScriptEngine& engine)
// base class QObject:
QScriptValue dptQObject = engine.defaultPrototype(qMetaTypeId<QObject*>());
// handle DACADClass
QScriptValue* protoDACADClass = new QScriptValue(engine.newVariant(qVariantFromValue((DACADClass *)0)));
protoDACADClass->setPrototype(dptQObject);
REcmaHelper::registerFunction(&engine, protoDACADClass, DACADPlugin::DACADClassToString, "toString");
engine.setDefaultPrototype(qMetaTypeId<DACADClass*>(), *protoDACADClass);
QScriptValue ctorDACADClass = engine.newFunction(DACADPlugin::createDACADClass, *protoDACADClass, 0);
engine.globalObject().setProperty("DACADClass", ctorDACADClass, QScriptValue::SkipInEnumeration);
// handle DAMachineModelVector
QScriptValue* protoMachineModelVector = new QScriptValue(engine.newVariant(qVariantFromValue((DAMachineModelVector *)0)));
protoMachineModelVector->setPrototype(dptQObject);
REcmaHelper::registerFunction(&engine, protoMachineModelVector, DACADPlugin::DAMachineModelVectorToString, "toString");
engine.setDefaultPrototype(qMetaTypeId<DAMachineModelVector*>(), *protoMachineModelVector);
QScriptValue ctorDAMachineModelVector = engine.newFunction(DACADPlugin::createDAMachineModelVector, *protoMachineModelVector, 0);
engine.globalObject().setProperty("DAMachineModelVector", ctorDAMachineModelVector, QScriptValue::SkipInEnumeration);
// handle DACADGlobals
QScriptValue* protoDACADGlobals = new QScriptValue(engine.newVariant(qVariantFromValue((DACADGlobals *)0)));
protoDACADGlobals->setPrototype(dptQObject);
REcmaHelper::registerFunction(&engine, protoDACADGlobals, DACADPlugin::DACADGlobalsToString, "toString");
engine.setDefaultPrototype(qMetaTypeId<DACADGlobals*>(), *protoDACADGlobals);
QScriptValue ctorDACADGlobals = engine.newFunction(DACADPlugin::createDACADGlobals, *protoDACADGlobals, 0);
engine.globalObject().setProperty("DACADGlobals", ctorDACADGlobals, QScriptValue::SkipInEnumeration);
And the functions referenced above in the include file:
#ifndef DACADPLUGIN_H_
#define DACADPLUGIN_H_
#include <QDebug>
#include <QObject>
#include <QScriptEngine>
#include <QStringList>
#include "RActionAdapter.h"
#include "RDocumentInterface.h"
#include "RGuiAction.h"
#include "RMainWindow.h"
#include "RPluginInterface.h"
#include "DACADClass.h"
#include "DAMachineModel.h"
\brief Brief
Detailed
class DACADPlugin: public QObject, public RPluginInterface
Q_OBJECT
Q_INTERFACES(RPluginInterface)
#if QT_VERSION >= 0x050000
Q_PLUGIN_METADATA(IID "com.duerkopp-adler.plugin")
#endif
public:
DACADPlugin();
virtual bool init();
virtual void uninit(bool);
virtual void postInit(InitStatus status);
virtual void initScriptExtensions(QScriptEngine& engine);
virtual RPluginInfo getPluginInfo();
// Access functions for intermal classes
static QScriptValue createDACADClass(QScriptContext* context, QScriptEngine* engine);
static QScriptValue DACADClassToString(QScriptContext *context, QScriptEngine * /*engine*/);
static DACADClass* getSelfDACADClass(const QString& fName, QScriptContext* context);
static QScriptValue createDAMachineModelVector(QScriptContext* context, QScriptEngine* engine);
static QScriptValue DAMachineModelVectorToString(QScriptContext *context, QScriptEngine* /*engine*/);
static DAMachineModelVector* getSelfDAMachineModelVector(const QString& fName, QScriptContext* context);
static QScriptValue createDAMachineModel(QScriptContext* context, QScriptEngine* engine);
static QScriptValue DAMachineModelToString(QScriptContext *context, QScriptEngine* /*engine*/);
static DAMachineModel* getSelfDAMachineModel(const QString& fName, QScriptContext* context);
static QScriptValue createDACADGlobals(QScriptContext* context, QScriptEngine* engine);
static QScriptValue DACADGlobalsToString(QScriptContext *context, QScriptEngine* /*engine*/);
static DACADGlobals* getSelfDACADGlobals(const QString& fName, QScriptContext* context);
public slots:
protected:
RGuiAction* createDACADAction(const QString &name, int sortOrder,RGuiAction::FactoryFunction factory);
#endif /* DACADPLUGIN_H_ */
QScriptValue DACADPlugin::createDACADGlobals(QScriptContext* context, QScriptEngine* engine)
if (context->thisObject().strictlyEquals(engine->globalObject())) {
return REcmaHelper::throwError(QString::fromLatin1("DACADGlobals(): Did you forget to construct with 'new'?"), context);
// constructor without arguments:
if(context->argumentCount() == 0) {
DACADGlobals* cppResult = new DACADGlobals();
return engine->newQObject(context->thisObject(), cppResult);
else {
return REcmaHelper::throwError(QString::fromLatin1("DACADGlobals(): no matching constructor found."), context);
QScriptValue DACADPlugin::DACADGlobalsToString(QScriptContext *context, QScriptEngine* /*engine*/)
DACADGlobals* self = getSelfDACADGlobals("toString", context);
return QScriptValue(QString("DACADGlobals(0x%1)").arg((unsigned long int)self, 0, 16));
DACADGlobals* DACADPlugin::getSelfDACADGlobals(const QString& fName, QScriptContext* context)
DACADGlobals* self = REcmaHelper::scriptValueTo<DACADGlobals >(context->thisObject());
if (self == NULL){
if (fName!="toString") {
REcmaHelper::throwError(QString("DACADGlobals.%1(): This object is not a DACADGlobals").arg(fName), context);
return NULL;
return self;
(As you can see, my knowledge of Qt is VERY limited ...)
Ulrich
PS: if you need, I can mail the complete sources! Please let me know!
