[SOLVED] Snapping restrictions
Taygete
Post by Taygete » Wed Feb 25, 2015 9:20 am
Hi Andrew,
I was wondering if there is a way to switch on snapping restrictions from within a script without the user having to select the restriction from the snap tools palette?
I can see you allow a user to enable the restrict angle length in the Line2P.js script but this is enabled via a button on the toolbar, I would like to enable this so it is always on in my script without the need for the user to enable it.
Thanks,
Andrew.
Re: Snapping restrictions
Post by andrew » Mon Mar 02, 2015 1:53 pm
You can use setSnapRestriction through the document interface:
di.setSnapRestriction(new RRestrictAngleLength(di));
Taygete
Post by Taygete » Fri Mar 20, 2015 12:36 pm
Hi Andrew,
Thanks for the guidance.
I had tried this previously but without success, so I tried again but it still doesn't add the "Restrict Angle or Length" ui components to my tools optionsbar. The only way I can get it too work is if I physically click the option from the CAD Tools bar.
I was hoping I could add the "Restrict Angle or Length" ui components to my tools optionsbar in code so the user doesn't need to click the restriction in the CAD Tool bar, should I be doing something else as well?
Thanks,
Andrew.
Post by andrew » Sat Mar 21, 2015 11:03 am
Taygete wrote:it still doesn't add the "Restrict Angle or Length" ui components to my tools optionsbar.
No. This sets the restriction mode for the document. UI components are handled on a different level entirely.
You could trigger the restriction tool programmatically (this is user interface level stuff):
var guiAction = RGuiAction.getByScriptFile("scripts/Snap/RestrictAngleLength/RestrictAngleLength.js");
guiAction.trigger();
Taygete
Post by Taygete » Sat Mar 21, 2015 8:32 pm
Hi Andrew,
Thanks for the information.
That got me a bit closer, the "Restrict Angle or Length" button in the CADTools is highlighted however I still don't get the "Restrict Angle or Length" ui components added to my tools optionsbar until I click the "Restrict Angle or Length" button on the CADTools.
I guess I must be doing something wrong but can't see what at the moment.
Thanks,
Andrew.
Post by andrew » Mon Mar 23, 2015 9:10 am
I see. Don't remember from the top of my head how that is implemented. Can you try:
di.setSnapRestriction(new RRestrictAngleLengthExtension(di));
Taygete
Post by Taygete » Tue Mar 24, 2015 9:14 am
Hi Andrew,
Thanks for the info.
It worked okay this time, I had tried calling setSnapRestriction previously on an earlier build of QCAD (version 3.6.1 I think) and couldn't get it to work however it works fine on 3.9.1.
I also needed to include the RestrictAngleLength.js script
include("scripts/Snap/RestrictAngleLength/RestrictAngleLength.js");
otherwise RRestrictAngleLengthExtension is unrecognised.
Thanks,
Andrew.
