Spline from Fit Points in Code
wildspidee
Post by wildspidee » Tue Feb 10, 2015 10:31 pm
Andrew,
I can't seem to locate anything on drawing a Spline from fit points (as opposed to control points). I currently have some control point splines such as :
var sleeveCapB = new RSpline([mA,mI,m3,mH,mE],2);
This works beautifully, of course. However, I have some splines that need to use fit points. I realize this is a Pro feature, but I am asking those that will be using my plug-in to purchase Pro. I won't develop or test in the unpaid version.
Thanks,
Lori
Re: Spline from Fit Points in Code
Post by andrew » Tue Feb 10, 2015 10:52 pm
There is no direct constructor for splines with fit points (QCAD wouldn't know which type is meant).
Instead, you can set the fit points for a spline after creating it:
var spline = new RSpline();
spline.setFitPoints([p1,p2,p3,...]);
Splines from fit points are always cubic (3rd degree splines).
