getMiddlePoint Question
wildspidee
Post by wildspidee » Fri Feb 06, 2015 7:20 pm
I'm using the middle point of a line to define a new RVector. My first inclination was to code:
var mO = new RVector(lD_K.getMiddlePoint());
This created an error. I did qDebug to see if something was wrong with the line:
    qDebug(lD_K + ' ldk');
    qDebug(lD_K.getMiddlePoint() + ' lD_K middle')
The results were fine:
Debug: RLine(RShape(address: "0x19d55f60"), startPoint: RVector(0, 23, 0), endPoint: RVector(15.25, 23, 0)) ldk
Debug: RVector(7.625, 23, 0) lD_K middle
I ended up doing this to solve the problem:
    var temp0 = lD_K.getMiddlePoint();
    var mO = new RVector(temp0.getX(),temp0.getY());
This works fine, but I would like to understand what the problem is. You can't create a new RVector using an existing RVector?
Thank you for your time.
Re: getMiddlePoint Question
Post by andrew » Mon Feb 09, 2015 9:13 am
You can simply write:
var mO = lD_K.getMiddlePoint();
Since getMiddlePoint returns a vector, mO will be assigned that vector.
wildspidee
Post by wildspidee » Mon Feb 09, 2015 3:31 pm
Overcomplicating seems to be something I do consistently. The obvious often eludes me.
Thanks Andrew.
