Hi again,
I'm looking around how to achieve the things I have to do ...
Just now internationalisation.
To make a text literal translateable, I enclose it into qsTr("").
Then I can extract the Strings with lupdate, use linguist to do the actual translation, and then use lrelease. Fine.
But: Is the lupdate / lrelease thing included in qmake process? I probalbly overlooked it ...
I cannot imagine that you do it manually for QCad.
Does there exist something like a howto, or can you please give me direction?
Thanks in advance and
Ulrich
How to translate ecma scripts
Re: How to translate ecma scripts
No. lupdate / lrelease are relatively slow, so running them on every build would not be practical.mink wrote:But: Is the lupdate / lrelease thing included in qmake process? I probalbly overlooked it ...
I do use some bash scripts to update and release translations. The script to update simply runs lupdate on the top level .pro file, lupdate updates recursively.I cannot imagine that you do it manually for QCad.
However, lrelease does not work recursively, so here I do something along the lines of:
for f in `find src -name "*.pro"`; do lrelease $f done
Thanks, Andrew, as always a very informative anser. I will dig into the lupdate / lrelease parameter and follow the bash aproach. This was I can restrict on my sources / scripts.
BTW, does the shared_ts.pri in the root of the source files give the correct clues?
Ulrich
Ulrich
This file defines the list of translation files that will be generated for all QCAD tools. If you want to generate the same translation files for your scripts, you can include this .pri file in your .pro files. Alternatively, you can simple define your own list of translations in your .pro file or in a shared .pri file included by all your scripts.mink wrote:BTW, does the shared_ts.pri in the root of the source files give the correct clues?
The misc tools for example only support a small subset of these translations as defined in scripts/Misc/translations.pri
