I read the post about menu order. However, to me it seems that it keeps one question open: how are the top level menu entries sorted? My newly created main menu entry is appended to the end of the menu (behind Help), which is pretty ugly.
How can I put my enty between Block and Window, for instance?
Is there an easy way, or do I have to programaticly use QT to shuffle the main menu entries?
Thanks for your help in advance!
Ulrich
Order of main menu
Re: Order of main menu
Yes, this might be your best (only?) option if your scripts are not wrapped as resources into a C++ plugin.mink wrote:or do I have to programaticly use QT to shuffle the main menu entries?
QCAD automatically initialises scripts (i.e. calls the init function of scripts) which are resources embedded in plugins before initialising the Help tools.
However, scripts that are added to the scripts directory are not as easily detectable.
