[SOLVED] Dynamically changing Widgets in a Layout
Nava2
Post by Nava2 » Wed Jan 21, 2015 4:10 pm
I'm trying to dynamically remove widgets from a QWidget and replace them with others.
Unfortunately, QtScript seems to be getting in the way.
The approved way to remove widgets is like so in C++:
QLayoutItem *child;
while ((child = layout->takeAt(0)) != 0)  {
    delete child;
A little digging shows this version:
  QLayoutItem* item;
  while ( !items_.isEmpty() && ( (item = items_.takeFirst()) != 0 ) ){
    layout()->removeWidget(item);
    delete item; // It works no matter where the item is
  items_.clear(); // clear the list afterwards.
Which is the way that is necessary since back links within the layout exists.
The problem is that this doesn't translate well to QtScript:
    var rootLayout = this.widget.layout();
    debugger;
    this.widgets.forEach(function (gb) {
        rootLayout.removeWidget(gb);
        delete gb;
    this.widgets = [];
This does not actually remove the Widget or delete it. The widgets remain persistant on the screen. When drawing new Widgets, they are drawn on top of these ones.
I then tried removing the layout, but that is not possible because of the QSharedPointer being maintained by QtScript.
delete rootLayout;
rootLayout = new QVBoxLayout();
this.widget.setLayout(rootLayout); // error Layout still set
Source: http://qt-project.org/doc/qt-4.8/qwidget.html#setLayout
So I'm at a loss as to how to replace widgets inside a single widget if I can't delete the Widget's layout like Qt expects.. :(
Nava2
Re: Dynamically changing Widgets in a Layout
Post by Nava2 » Wed Jan 21, 2015 10:50 pm
I also tried QWidget::destroy but that didn't remove them.
Nava2
Post by Nava2 » Wed Jan 21, 2015 11:51 pm
Using QObject::destroy() slot made this work.
