QCad crashes in debug mode
mbpcmeo
Post by mbpcmeo » Mon Jan 05, 2015 7:11 pm
I'm writing a simple script to play around with objects provided by the framework by setting the breaking point when a line is selected. The script can be found in the attached file. Qcad is launched with this argument:
-rescan -enable-script-debugger
The program crashes each time I want to investigate the variable's content with this below error. Please see the attached file for complete error
VM Region Summary:
ReadOnly portion of Libraries: Total=407.4M resident=179.9M(44%) swapped_out_or_unallocated=227.6M(56%)
Writable regions: Total=223.1M written=69.9M(31%) resident=105.3M(47%) swapped_out=40K(0%) unallocated=117.7M(53%)
I have about 2.5GB free RAM when launching Qcad so I don't think this is due to the lack of RAM as the error seems to suggest.
Does anyone have the same error ? How do you do to make sure that the error does not happen again ?
Here is the error on the command line, maybe it can be useful ...
2015-01-05 19:03:24.082 QCAD[2411:176191] NSSoftLinking - The ShareKit framework's library couldn't be loaded from /System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/ShareKit.
2015-01-05 19:03:24.083 QCAD[2411:176191] NSSoftLinking - The ShareKit framework's library couldn't be loaded from /System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/ShareKit.
Debug:    SvgImporter.prototype.importFile
Warning:  RScriptHandlerEcma::RScriptHandlerEcma: script debugger enabled! Not recommended.
Floating point exception: 8
Thanks a lot in advance !
qcad-crash.txt
(3.03 KiB) Downloaded 455 times
Connhon.js
(984 Bytes) Downloaded 426 times
Re: QCad crashes in debug mode
Post by andrew » Mon Jan 05, 2015 9:48 pm
Which variable are you trying to investigate?
You might want to print the variable to stdout instead:
qDebug(myObject);
