I have done a search and haven't been able to find this feature.
I currently set some custom properties in a script which the user can then view and change in the property editor, however there is some data I would like to make read-only so the user cannot change it.
Ideally I would like to be able to set a flag when setting the custom property to be read-only (or another choice might be to make it visible/hidden in the property editor), is this possible?
Thanks,
Andrew.
Is it possible to make custom properties read-only
- hungerburg
- Premier Member
Re: Is it possible to make custom properties read-only
Not an authoritative answer, but I studied xdata in the dxf spec and there is no such flag there. As dxf is the standard file format in qcad such a feature would require a proprietary extension.
Hi hungerburg,hungerburg wrote:Not an authoritative answer, but I studied xdata in the dxf spec and there is no such flag there. As dxf is the standard file format in qcad such a feature would require a proprietary extension.
Thanks for the info, I guess that is why there isn't this option already.
Andrew.
- hungerburg
- Premier Member
You could put the data that you want to hide from the users below a different APPID than the one users are to modify themselves, so there is at least some visual separation.
Hi hungerburg,hungerburg wrote:You could put the data that you want to hide from the users below a different APPID than the one users are to modify themselves, so there is at least some visual separation.
Thanks for the idea, I will take a look into that.
Andrew.
There's definitely some room for improvement for the handling of custom properties.
QCAD stores custom properties as strings in the format 'key:value".
This notation is entirely QCAD specific and could be extended to contain other information such as:
ReadOnly, // Property is read only Invisible, // Property is not displayed Angle, // Property is an angle (shown in user preferred angle unit) RichText, // Property is rich text and can be edited as such Style, // Property is a text style (font) Label, // Property is a label (suggests context menu to insert symbols) Pattern, // Property is a hatch pattern name Integer, // Property is an integer number Double, // Property is a double (real) number Boolean, // Property is a boolean (true or false) List // Property is one of several choices presented in a combo boxAnd possibly others. Any thoughts?
Hi Andrew,andrew wrote:There's definitely some room for improvement for the handling of custom properties.
This notation is entirely QCAD specific and could be extended to contain other information such as:ReadOnly, // Property is read only Invisible, // Property is not displayed Angle, // Property is an angle (shown in user preferred angle unit) RichText, // Property is rich text and can be edited as such Style, // Property is a text style (font) Label, // Property is a label (suggests context menu to insert symbols) Pattern, // Property is a hatch pattern name Integer, // Property is an integer number Double, // Property is a double (real) number Boolean, // Property is a boolean (true or false) List // Property is one of several choices presented in a combo boxAnd possibly others. Any thoughts?
All those on your list are good ideas, the readonly and invisible are particularly interesting to me.
I will have a think on this and if I come up with any questions or further ideas will post back.
Thanks,
Andrew.
