Removing an image entity
s4eed
Post by s4eed » Tue May 13, 2014 8:51 am
Hello dear friends.
I add an image entity to my map using this code :
	var i = new RImageEntity(
		document,
			 new RImageData("scripts/MyScripts/tick.png",
							new RVector(0,0),
							new RVector(1,0),
							new RVector(0,1),
							50, 50, 0)
	documentInterface.setRelativeZero(point);
	i.setWidth(2);
	i.setHeight(2);
	i.setInsertionPoint(point);
	TickImageEntites[entId] = i;
Suppose that entId is a unique key associated to each ImageEntity and TickImageEntites is something like this :
var TickImageEntites = {};
Then I want to remove all of this image entities inside TickImageEntites using this code :
		for (var k in TickImageEntites) {
			QMessageBox.information(0,"msg", "id:"+k);
			var op = new RDeleteObjectOperation(TickImageEntites[k], false);
                        di.applyOperation(op);
But my code doesn't work at all! What the problem. thanks.
Re: Removing an image entity
Post by andrew » Tue May 13, 2014 11:18 pm
You might want to print TickImageEntites[k] in your for loop, to check if these are valid entities with a valid ID, etc.
