Hi friends especially dear Andrew.
I want to add several exclamation marks(For example a .png file) to my documents in some predefined points just for alerting the user that these points in map have a problem. I do not want the document to be modified.
Something like what I attached.
Adding a exclamation mark to a map just for preview?
- sshot-1.png (20.74 KiB) Viewed 4329 times
Re: Adding a exclamation mark to a map just for preview?
Adding something to a document is (by definition) a modification of said document.
I'd suggest to add the marks and save the document under a new name or export it to PDF to hand it back to the user.
