why qcad-3.4.6.0 compiled completely but can't run?
jzq740176597
Post by jzq740176597 » Wed Apr 16, 2014 2:43 am
like title metioned, I use vs2010,QT4.8.5 compiled the source successfullly,but when debuging run, it failed.
problem located in
 // iterate through module list and break if one module cannot be loaded
    QStringList modules;
    modules << "qt.core" << "qt.gui" << "qt.uitools" << "qt.webkit" << "qt.sql"
            << "qt.svg" << "qt.xml" << "qt.xmlpatterns";
#ifndef Q_OS_WIN32
    // NOTE: qt.network wrapper does not compile under Windows (SSL problems)
    modules << "qt.network";
#endif
    for (int i=0; i<modules.size(); i++) {
        engine->importExtension(modules.at(i)); [b]//this line![/b]
engine->importExtension(modules.at(i)); will goto %qcadDir%/plugins/script find some DLL. but is blank in my case even though compiled successfully.
in that folder there's only a readme.txt, prompt "Script plugins will be compiled with QCAD into this folder."
I don't understand what's it means.
any advice will be appreciated.
