Identifying entities recently added
sramp
Post by sramp » Wed Feb 05, 2014 12:29 pm
I'm modifying the Line2p.js scritp since I would like to create a new tool able to create automatically a new block built with a closed polygon.
To create the block I need to know the entities which forming the closed polygon.
Is there a way to know the ids of these entities?
I see that the entity is created in the getOperation method, but I suppose that the id of the entity will be assigned after the RAddObjectOperation completion, since here the id is still -1
 Line2P.prototype.getOperation = function(preview) {
    var line = new RLineEntity(
        this.getDocument(),
        new RLineData(this.point1, this.point2)
    return new RAddObjectOperation(line);
sramp
sramp
Re: Identifying entities recently added
Post by sramp » Thu Feb 06, 2014 11:38 am
maybe I've found a solution of my problem.
I have added to my script a RTransactionListenerAdapter.
In this way I can retrieve the ids of the segments while I'm building the closed polygon.
To learn more just study the example script ExTransactionListener.js.
Please let me know if there is a different and better solution.
sramp
Post by andrew » Thu Feb 06, 2014 11:46 am
Yes, a transaction listener is the solution to use whenever you need to know what is 'going on' in a drawing. All objects that are added or modified go through a transaction.
