Slovenian translation
Re: Slovenian translation
Hi!
translation is now ready for GitHub.
I noticed that there are some parts especially under settings that aren't translatable. Is that correct?
That's great news indeed!miharix wrote:translation is now ready for GitHub.
No, that shouldn't be the case. Do you have a specific example? Thanks.miharix wrote:I noticed that there are some parts especially under settings that aren't translatable. Is that correct?
Here is Screen Capture of an example.
When I change language to any other is the same.
- DE
- non_translate_de.png (140.26 KiB) Viewed 15151 times
- SLO
- non_translate.png (142.41 KiB) Viewed 15151 times
Thanks for the hint. I've fixed this in the current git master branch.
I've finally had a chance to set up a translation server this week. So the Slovenian translation is now hosted at:
http://translate.qcad.org/sl/
Wow a translation sever. I didn't know that such things exist. Impressive software!
I see that QCAD pro and QCAD/CAM are totally untranslated.
Are this so many additional strings? Because I looked a little on strings of QCAD pro and some do look familiar.
Ps: When do you plan to build the installer including Slovenian translation for http://qcad.org/en/qcad-downloads-trial
Yes, these are two commercial / proprietary add-ons for QCAD.miharix wrote:I see that QCAD pro and QCAD/CAM are totally untranslated.
Yes, there is likely some overlap as some QCAD Pro tools are based on simpler versions of the same tools contained in the free QCAD community edition.Are this so many additional strings? Because I looked a little on strings of QCAD pro and some do look familiar.
The 3.4.6 release is work in progress. There is only one important bug fix pending at this point.Ps: When do you plan to build the installer including Slovenian translation for http://qcad.org/en/qcad-downloads-trial
Is there any way to have commercial add-ons translated?andrew wrote:Yes, these are two commercial / proprietary add-ons for QCAD.miharix wrote:I see that QCAD pro and QCAD/CAM are totally untranslated.
QCAD Professional can also be translated online at:
Please understand that we are relying on the QCAD community for translation into languages which are not officially supported. Currently officially supported are: English, German, French, Spanish, Portuguese.
QCAD/CAM is currently only translated into English and German.
